Refind as a default bootloader
Hi I have a question,
Are there any plan to move the bootloader from grub what currently bazzite has to rEFInd out of the box?!
or is there an “official way” to have it installed in bazzite instead of the actual default one and not having to create a layer with rpm-ostree?
To have a more modern and functional couch experience even when you dual boot and using the lizard mode of a steam controller for example to achive the real couch experience.
Thank you
These things come from upstream, so we move when Fedora moves. But Refind hasn’t been talked about.
Probably systemd-boot at some point with the -sealed images, whenever they are ready
ah good to know, ok thank you for the update :slight_smile:
So I guess the only way for me to have rEFInd at the moment would be the rpm-ostree route then am I correct?
I have zero idea. Probably won’t even work.
