What is Rebasing?
Attention: Do not rebase between different desktop environments.
Rebasing allows users to switch to a different image without having to reinstall and lose personal files and application data.
It is recommended to use the Bazzite Rollback Helper utility.
Rebase Scenarios
- Rebase to specific images of older builds within the last 90 days if issues are occurring on the newest build of Bazzite.
- Rebase to other Fedora Atomic Desktop images including other Bazzite images.
- Do not rebase between different desktop environments.
How do I swap between Bazzite (and other Fedora Atomic Desktop) images?
See what channel or build you are on by entering this command in a host terminal:
rpm-ostree status
Check under “Deployments:” and the output should be similar to:
● ostree-image-signed:docker://ghcr.io/ublue-os/[image]:[channel]
Switch to another Bazzite variant by entering the command for each specific image.
Open the terminal and enter:
rpm-ostree rebase <image>
Example:
rpm-ostree rebase ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-deck:stable
For rebasing to the generic KDE Plasma version of the Handheld & HTPC image.
NOTE: Rebasing between different desktop environments may cause issues and is unsupported.
How do I change the Bazzite’s update branch? (Stable, Testing, and Unstable)
There are 3 branches you can switch to:
- Stable (
:stable
)- Default branch that’s used in normal Bazzite installations
- Testing (
:testing
)- Get a sneak peak of future Bazzite builds before release
- Bugs may frequently appear
- Encouraged to rebase back to
:stable
after the major new feature is in Stable
- Unstable (
:unstable
) (DO NOT USE)- Not recommended
- Testing playground for developers/contributors
- Can be several months behind compared to both
:stable
and:testing
updates - Intended for testing desktop environments and other radically changed functionality to Bazzite for the future
If you enabled advanced update channel, then additional options will appear. The options map as the following:
Stable (:stable)
Release Candidate (:testing)
Beta (:testing)
Beta Candidate (:unstable)
Main (:unstable)
For Desktop images, replacing :stable
with :testing
or :unstable
to the end of the rebase command for your Bazzite image allows you to switch to the experimental branches (which may have frequent bugs.)
Example:
rpm-ostree rebase ostree-image-signed:docker://ghcr.io/ublue-os/bazzite:testing
For the testing branch on the generic AMD/Intel Desktop image.
Can I stay on a specific Fedora release?
Warning: You will have to rebase back to
:stable
once you want to upgrade to the next Fedora version.
Note: Switching to older Fedora versions will not bring new updates until you upgrade back to
:stable
and this also means no security updates for the time being.
Yes, but only if that version of Fedora is still currently supported upstream.
- Replace
:stable
with the supported version of Fedora you would like to stay on. - Fedora Rawhide is not supported.
Rebasing to older builds
:stable
once you want to upgrade to the newest release.
- Like rolling back to the previous Bazzite deployment, users can also rebase to a specific Bazzite builds that was were built within the last 90 days.
- All of your userdata will remain intact, but like how the warning indicates above, you will have to rebase manually back to
:stable
to update the system to receive the newest build.
View the list of available builds by entering:
skopeo list-tags docker://ghcr.io/ublue-os/bazzite | grep -- "-stable-" | sort -rV
Rebasing to a specific build requires users to open a host terminal and enter:
rpm-ostree rebase ostree-image-signed:docker://ghcr.io/ublue-os/IMAGE-NAME:VERSION-YEARMONTHDAY
Example:
rpm-ostree rebase ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-deck:39-20240113
For the Jan. 13th 2024 bazzite-deck
(Fedora 39) build.
