I only have one distrobox and I think I had the reboot problems before I made a distrobox, so I don’t know if they’re related to my reboot but they might be for yours.
the -1 parameter on journalctl is a count-backwards of current reboots. -0 is the current boot, -1 is the previous boot, -2 is the one before that, etc.
I’d be curious, if your Bazzite is kind enough to stay online for it, if you could walk back in your reboots and see if they’re always ended with distrobox stuff.
Mine is usually discord info spam about loaded resources not being used fast enough, I think.
Jun 10 09:56:54 Clippy.lan flatpak[10382]: 09:56:54.356 › The resource https://discord.com/assets/189422196a4f8b53.woff2 was preloaded using link preload but not used within a few seconds from the window's load event. >
Jun 10 09:56:54 Clippy.lan flatpak[10382]: 09:56:54.356 › The resource https://discord.com/assets/ce3b8055f5114434.woff2 was preloaded using link preload but not used within a few seconds from the window's load event. >
Jun 10 09:56:54 Clippy.lan flatpak[10382]: 09:56:54.356 › The resource https://discord.com/assets/cb2006dbced0e246.woff2 was preloaded using link preload but not used within a few seconds from the window's load event. >
Jun 10 09:56:54 Clippy.lan flatpak[10382]: 09:56:54.356 › The resource https://discord.com/assets/7a6a566c2e88a35d.woff2 was preloaded using link preload but not used within a few seconds from the window's load event. >
Jun 10 09:56:54 Clippy.lan flatpak[10382]: 09:56:54.356 › The resource https://discord.com/assets/e52f0cba712e2fb4.woff2 was preloaded using link preload but not used within a few seconds from the window's load event. >
Jun 10 09:56:54 Clippy.lan flatpak[10382]: 09:56:54.357 › The resource https://discord.com/assets/dd24010f3cf7def7.woff2 was preloaded using link preload but not used within a few seconds from the window's load event. >
Jun 10 09:57:06 Clippy.lan flatpak[10382]: 09:57:06.282 › The resource https://discord.com/assets/189422196a4f8b53.woff2 was preloaded using link preload but not used within a few seconds from the window's load event. >
Jun 10 09:57:06 Clippy.lan flatpak[10382]: 09:57:06.282 › The resource https://discord.com/assets/ce3b8055f5114434.woff2 was preloaded using link preload but not used within a few seconds from the window's load event. >
Jun 10 09:57:06 Clippy.lan flatpak[10382]: 09:57:06.283 › The resource https://discord.com/assets/cb2006dbced0e246.woff2 was preloaded using link preload but not used within a few seconds from the window's load event. >
Jun 10 09:57:06 Clippy.lan flatpak[10382]: 09:57:06.283 › The resource https://discord.com/assets/7a6a566c2e88a35d.woff2 was preloaded using link preload but not used within a few seconds from the window's load event. >
Jun 10 09:57:06 Clippy.lan flatpak[10382]: 09:57:06.283 › The resource https://discord.com/assets/e52f0cba712e2fb4.woff2 was preloaded using link preload but not used within a few seconds from the window's load event. >
Jun 10 09:57:06 Clippy.lan flatpak[10382]: 09:57:06.283 › The resource https://discord.com/assets/dd24010f3cf7def7.woff2 was preloaded using link preload but not used within a few seconds from the window's load event. >
Jun 10 09:57:23 Clippy.lan flatpak[10382]: 09:57:23.426 › The resource https://discord.com/assets/189422196a4f8b53.woff2 was preloaded using link preload but not used within a few seconds from the window's load event. >
Jun 10 09:57:23 Clippy.lan flatpak[10382]: 09:57:23.426 › The resource https://discord.com/assets/ce3b8055f5114434.woff2 was preloaded using link preload but not used within a few seconds from the window's load event. >
Jun 10 09:57:23 Clippy.lan flatpak[10382]: 09:57:23.426 › The resource https://discord.com/assets/cb2006dbced0e246.woff2 was preloaded using link preload but not used within a few seconds from the window's load event. >
Jun 10 09:57:23 Clippy.lan flatpak[10382]: 09:57:23.426 › The resource https://discord.com/assets/7a6a566c2e88a35d.woff2 was preloaded using link preload but not used within a few seconds from the window's load event. >
Jun 10 09:57:23 Clippy.lan flatpak[10382]: 09:57:23.426 › The resource https://discord.com/assets/e52f0cba712e2fb4.woff2 was preloaded using link preload but not used within a few seconds from the window's load event. >
Jun 10 09:57:23 Clippy.lan flatpak[10382]: 09:57:23.426 › The resource https://discord.com/assets/dd24010f3cf7def7.woff2 was preloaded using link preload but not used within a few seconds from the window's load event. >
