Proton VPN Port Forwarding
Hello, how would I go about following these port forwarding rules on Bazzite/Aurora? How to manually set up port forwarding | Proton VPN
I can skip step 1 because I use the GUI but in step 2, they want me to run sudo dnf install natpmpc. This command does not work for me on Bazzite. I also tried dnf list libnatpmp to see if it was maybe already installed but it doesn’t seem like it. I also tried dnf search libnatpmp which said was not implemented and to use the toolbox command instead - would this be able to help? I’ve never used it before but I ran toolbox create - is this similar to a distrobox?
I poked around with layering natpmp when I moved to bluefin but I could never get protonvpn portforwarding working. I don’t really have the understanding of networking to know why it didn’t work and gave up in the end. I wish you luck!
