Plasma intergration broken
hi so when i try Plasma intergration kde just does not find it i tried using chrome and firefox to test it both of them did not detected it
Btw i installed bazzite on top of fedora kinoite
Are you using Flatpak version of Chrome and Firefox? If so, they do not work right now, due to the portal (permissions) for them not being implemented yet. See: webextensions: add a portal for managing WebExtensions native messaging servers by jhenstridge · Pull Request #705 · flatpak/xdg-desktop-portal · GitHub
If you’re using something else, then that depends on how you installed it. In a distrobox, you’d want to also install the plasma integration package on that distrobox as well. Nix works just fine by default IIRC.
I think i am using the fedora version of firefox
Google chrome is from flatpack
