Hello, I’ve been struggling to find a solution to my screen being stuck upside down in gamemode. I was able to change the orientation for desktop mode, but not having any luck with gamemode.
Since this is an immutable OS, my options are limited to what I can do to try and fix this.
I’ve already tried editing “rpm-ostree kargs” with panel_orientation but with no luck.
In case you still have issues with this, I connected an external display to the handheld before making changes to the kernel arguments. This might help you also.
Did this get fixed ever? Just bought OneXFly R7-8840U and after Bazzite installation → issue is still active. Gamemode + desktop are upside dow. Desktop can be turned to correct orientation from settings but this happen again after reboot. Gamemode dont have this option in settings
