NVIDIA headless
Hello,
What is the recommended way to install NVIDIA drivers for AI only? My main GPU is a Radeon (the one connected to the monitor). The NVIDIA GPU will be used only when launching LLM models. I have a working installation of Aurora running fine with my AMD gpu.
Thanks!
You need to move to the Nvidia image if you want the Nvidia GPU to work. Not much else you can do / need to do
