No connection to ucore server
I think I must be missing something obvious here. I’m trying out ucore on a couple of servers and I am unable to connect to them from other machines on the LAN.
I’ve tried to ping the IP addresses, tried to connect via SSH and tried a simple python server command, all without any success. I’ve also tried stopping the firewalld service and still no luck.
If I enable tailscale, things work a lot better, although, connecting to simple podman services gives my a “Secure Connection Failed” response with “Error Code: SSL_ERROR_RX_RECORD_TOO_LONG”
Outgoing connections work fine with or without tailscale.
Any suggestions would be greatly appreciated.
PS: My simple ignition file is:
  "ignition": {
    "version": "3.5.0"
  "passwd": {
    "users": [
        "groups": [
          "sudo",
          "wheel"
        "name": "mal",
        "passwordHash": "..."
I’ve been investigating this further and have learnt a few things:
  • I don’t have a good understanding of firewalld, so it’s better to let cockpit manage access to services and ports.
  • SSH passwords are disabled by default in uCore - the ignition file should include an ssh public key to allow SSH access out of the box.
  • I have uBlock Origin running in Firefox and it has been blocking access to my uCore test server.
After sorting out these issues, I’m now making progress with uCore.
