rhuze
1
Hey all,
I’m new here. I recently posted a GitHub repo that runs mining software on Aurora (to be expanded to other Ublue variants) using Toolbox.
It stopped working this morning with the error:
CUDA error: file too short
I dug around and found this:
ls -l /usr/lib64/libcuda.so.570.86.16
-rw-r--r--. 1 root root 0 Feb 17 22:52 /usr/lib64/libcuda.so.570.86.16
For some reason it has a 0-byte file size.
Here is my system info if it helps:
- I am running Aurora-DX 41
- Quadro RTX 5000
- Driver Version: 570.86.16
- CUDA Version: 12.8
It seemed to happen after the latest update, but the issue persisted when I rolled back to the pre-update image.
I am not sure if this is the proper place to post this. My time is extremely limited currently and this was my quickest option.
Thank you. I love Aurora and Ublue.
This is what what I see for that file in Bluefin-DX (which should be same):
❯ ls -l /usr/lib/libcuda.so.570.86.16
-rwxr-xr-x. 3 root root 25609636 Jan 1 1970 /usr/lib/libcuda.so.570.86.16
❯ sha256sum /usr/lib/libcuda.so.570.86.16
0534de781601dec878f51f7478e38d58664b42e1ce4bdf2996cf7384cbc40372 /usr/lib/libcuda.so.570.86.16
Clearly your system’s atomic partition is broken. Did any update fail? Can you boot into the previous installation?
I would suggest re-paving the OCI image to see if it works.
rhuze
3
Thank you, re-paving worked. I am new to Atomic distros so it wasn’t clear to me that the atomic partition was broken.
I hope my initial post didn’t come off as rude. My social skills are not the best. I wasn’t complaining and apologize if it came off that way.
Much appreciated.
