Menu is not showing options - Rog Ally
After one of the system updates or Flatpak updates last week, I noticed that menu options is not showing. Like it is collapsed or something. I can hear me running down the list when I navigate with controller and I can select, but I have to guess where I’m at. Anyone had this before or know a fix? I ignored at first and waited for next update, but the following updates didn’t remedy it.
Any ideas? Maybe how to reset?
I’ve got the same issue here. I’ve tried both rolling back the last couple months of updates and doing a rebase to latest stable release, and still have issues.
The performance settings in QAM is also affected, so I’m stuck at a low TDP right now.
Did you manage to find a solution?
Cameron
No sorry, not yet. I’m probably just going to re-install, if I don’t find a solution soon.
I have decided today, to re-install Bazzite. Now everything is working as it should, but of course I have to setup everything from scratch again.
