Manpages oddities
man -k <search pattern> searches for man pages containing the <search pattern>
However it doesn’t show all.
  1. It doesn’t show any man page from brew installed software
  2. It doesn’t show any man page from packages
    • which are layered
    • which are installed in a custom image
Is there anything what can be done here?
Hm, something was wrong with the /var/cache/man directory. When I ran sudo mandb all files except the index.db were updated.
So I did the following
  • deleted the /var/cache/man directory
  • ran sudo mandb
  • now index.db was up to date
and man -k works fine again.
Have to investigate what exactly man-db-cache-update.service does.
EDIT: Of course, the only pain point are brew packages whose man pages are not caught.
What I did manually, by deleting the /var/cach/man directory and running sudo mandb should be handled correctly by the man-db-restart-cache-update.service
I got man -k … work correctly with brew man pages by adding a line
MANDB_MAP /home/linuxbrew/.linuxbrew/share/man /var/cache/man/linuxbrew
to /etc/man_db.conf
Then running
sudorm -rf /var/cache/man and sudo mandb
Now man -k <pattern> is working fine.
One (hopefully) last remark. :grin: It seems that sudo systemctl start man-db-restart-cache-update.service works ok as well. Perhaps I initially misinterpreted things here.
