Logitech Saitek Side Panel
Not sure if this is the right place to post but I can’t find a solution for this anywhere.
I’m using the Logitech Saitek Heavy Equipment Bundle steering wheel and side panel for playing FS25. The wheel and padels work fine but the side panel is showing up as a Xbox controller in steam and under the controller settings in Bazzite, so I can’t map every button in the game.
I have tried the basic stuff such as disabled steam input for the game and trying different Usb ports on my computer. I have searched the web for this issue and found a couple of people with the same issue but none had a solution.
I used to run Linux Mint before and I did not have this issue, it was just plug and play. I know Bazzite is not as “tweakable” as Mint but i’m thinking that it might be a issue with the built in logitech drivers in Bazzite. Is there a way to change or update the drivers or should I search for a custom driver that might help?
