Live ISO testing for Aurora
Alright people
It is testing time!
Just like on Bluefin we now have created Live environment installer ISOs for Aurora.
These ISOs are based on the awesome work by M2 on titanoboa and anaconda. So now we have “full feature” live environment ISO that also has a new WebUI Anaconda installer, which is only available on the normal Fedora Workstation (gnome) ISOs.
These images are not (at this point) available on the download picker at https://getaurora.dev which has the old non-live old anaconda installer.
I have tested the image during the weekend and it works nicely. BUT (there is always a but) there is one issue that you should be aware of. The installer only has US keyboard layout which cannot be changed. This is because the upstream version of WebUI anaconda is currently hard coded to gnomes control center for the keyboard layout (on gnome it just opens the gnome settings panel in the keyboard section).
So during the install you cannot change the keyboard layout, so be aware when you install with encryption that you know how to type the LUKS password once you boot.
Download the Live ISO:
Intel/AMD: https://dl.getaurora.dev/aurora-stable-live.iso
Nvidia (open): https://dl.getaurora.dev/aurora-nvidia-open-stable-live.iso
KNOWN ISSUES
  • Keyboard layout cannot be changed in the installer or LUKS prompt
    - Might get fixed with the next anaconda webUI version
  • Installer icon is missing
Auora-Nvidia live boot does NOT work for me. It gets stuck in a loop while waiting for something to complete, then gives up and drops me into recovery mode where I can’t do anything useful.
Log: rdsosreport.txt
I normally use Bazzite and it works fine, as do other distros and live boot images that I’ve used.
