I search how to install libavcodec.so.60 for test the new emulator Citron. I’ve FFmpeg but the version of codec is 61. I don’t undertstand how to do that. I suppose i’m noob.
Thanks
I also having same issue and installing older version of libriares are beyond my power.
thank you to answer me. Do you know how to do this or do you have a tutorial?
Hello, I was able to run citron in bazzite but I had to download the necessary libraries and run a command in the terminal
first I create a directory to put the libs and i run this command to run citron
LD_LIBRARY_PATH=$PWD/lib64:$LD_LIBRARY_PATH ./citron
I downloaded this libs i dont now if this is the best way to run citron but work
I used rpmfind to download this libs
libavcodec.so.60
libavutil.so.58
libjxl_threads.so.0.8.3
libswscale.so.7
libx265_main12.so.209
libavcodec.so.60.31.102
libavutil.so.58.29.100
libplacebo.so.338
libswscale.so.7.5.100
libx265.so.209
libavfilter.so.9
libhdr10plus.so
libpostproc.so.57
libtesseract.so.5.3.4
libavfilter.so.9.12.100
libjxl.so.0.8
libpostproc.so.57.3.100
libvmaf.so.1
libavformat.so.60
libjxl.so.0.8.3
libswresample.so.4
libvmaf.so.1.1.2
libavformat.so.60.16.100
libswresample.so.4.12.100
libx265_main10.so.209
Thanks! Worked perfectly! I’ve made .sh shortcut to run this command, but there is any way to run this in Gaming Mode? Simply add to steam sh file did not work ![]()
