KVM Issue - VM have disappeared
Running into an issue with KVM. I went to startup the VM for W11 and it was not on the list of VMs. All Vms are gone from KVM list.
After asking Grok i ran the following:
sudo ls -lZ /var/lib/libvirt/images/
total 78206840
drwx–x–x. 1 root root system_u:object_r:virt_image_t:s0 0 Jan 17 13:22 pool-1
-rw-r–r–. 1 107 107 system_u:object_r:virt_image_t:s0 789645312 Jan 17 13:03 virtio-win-0.1.285.iso
-rw-r–r–. 1 107 107 system_u:object_r:virt_image_t:s0 7736125440 Jan 17 14:02 Win11_25H2_English_x64.iso
-rw-------. 1 root root system_u:object_r:virt_image_t:s0 35508977664 Mar 25 23:11 win11-clone.qcow2
-rw-------. 1 root root system_u:object_r:virt_image_t:s0 85912715264 Apr 15 18:14 win11.qcow2
I believe this is my missing VM. It still does not appear in the list when I launch KVM.
I then ran:
sudo systemctl restart libvirtd
Failed to restart libvirtd.service: Unit libvirtd.service not found
Not sure what to do next. Any help would be appreciated.
Operating System: Bazzite 44
KDE Plasma Version: 6.6.4
KDE Frameworks Version: 6.26.0
Qt Version: 6.10.3
Kernel Version: 6.19.14-ogc2.1.fc44.x86_64 (64-bit)
Graphics Platform: Wayland
Processors: 16 × 11th Gen Intel® Core™ i9-11900K @ 3.50GHz
Memory: 32 GiB of RAM (31.2 GiB usable)
Graphics Processor: AMD Radeon RX 6700 XT
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: Z590 AORUS ULTRA
System Version: -CF
I ran into the same issue. QEMU was removed from the Bazzite 44 base image. You can rebase to Bazzite DX or rollback to Bazzite 43.
Thank you, why would they even do that. Been using Bazzite as my daily diver since January, this is the first issue if had.
Here are the major changes: Bazzite 44 Update
“Images reduced by 1GB thanks to moving in-image QEMU and ROCM to [Bazzite-DX](https://dev.bazzite.gg/) for users who need them”
Easiest way to fix is to install opencode and just ask it to fix your virtualization. Had the same thing happen and opencode fixed it all and brought back my VMs.
