Is it worth layering VirtualBox in UBlue? Is there any other way to install it?
I have been debating myself if I just should keep using QEMU with Virtual Manager for my new virtual machines, after converting them. Or should I install VirtualBox by layering it?
What is your take?
What are you experiences after converting VirtualBox VMs into objects being managed by Virtual Manager?
Virtualbox requries kernel modules. While this would be possible if you build an image, we already have qemu fully supported on the dx images.
Personally I’ve been happy with using either VirtualManager or Incus as a frontend for qemu.
