Installing tarball - radio tray application
Hi,
I only installed something from source once, just following a step by step guide (copying lines to the terminal).
I will use as much as possible only Flatpak applications. I didn’t found a system tray radio, I used this one before: Radio Tray download | SourceForge.net
Is it difficult of unwise to install this?
If you’re on Gnome you can use SomaFM extension. I use it and it works very well. You can also edit the config to add your own stations.
https://extensions.gnome.org/extension/1237/somafm-internet-radio/
Perfect solution, thank you!
