Hi there,
I would like to install Android 11 so I can use widevine (widevine is not supported with Android 13), is there any way to do this?
I checked https://ota.waydroid.id and it is pointing to Android 13 so that gets installed.
I checked the waydroid command, you can do
waydroid init -f
which allows you to use your own Android images but that looks at a directory in /etc which is not writable so I cannot use that.
I am a bit stuck.
Thanks for any help,
Jason
