How do I install VirtualBox?
I’m trying to install VirtualBox, but I don’t know how to do it. I was thinking about using Gnome Boxes or Virtual Machine Manager, but the problem is that I need to export and import the virtual machines, and they are in OVA format, and I don’t know how to do it. Can anyone help me?
You will need to either use a container which you’ve set up using BoxBuddy, or set up a new one.
You can then install VirtualBox in that container following the normal instructions:
https://www.virtualbox.org/wiki/Linux_Downloads
Once you have the container, e.g. Debian or Fedora, you can then use the terminal to install it in that container like a normal distro.
Here’s an example of how someone does it on Bazzite, but the principle is the same on Bluefin or Aurora.
I’m not affiliated with this YouTuber in any way.
Regarding virtual machine image format conversion: I used this article on linuxconfig.org to convert VirtualBox OVA format to QCOW2 format. QCOW2 can be used to create virtual machines with QEMU/KVM or virt-manager which are available by default in DX flavours of Bluefin or Aurora. Not sure about Bazzite though.
