Flatpacks backups?
I’m using Picka Backup to do a /Home backups, Is there any way to do all installed flatpacks backups as well. Where are there in the system ?
I’ll try it, thanks.
~/.local/share/flatpak
/var/lib/flatpak
~/.var/app
So these are the locations to save and restore and would work again?
Hiw do they don’t on these images then?
Why flatpacks don’t have one folder / one location but there are in so many or that some of their user data?
I too would like to know incase I do a fresh install I want a off-line restore method for flatpaks installed
