I’m not sure why I can’t browse the extensions, it’s been a while I think.
My network connection is good.
Thanks
I’ve had this on machines with multiple nics and GNOME thinks the unplugged one is the connection. I turned the ones I wasn’t using off and that solved it.
Hey Jorge, I don’t understand what you’re saying but want to!
It looks like I have 3 nics up right?
nmcli device status
DEVICE TYPE STATE CONNECTION
enp3s0 ethernet connected enp3s0
tailscale0 tun connected (externally) tailscale0
lo loopback connected (externally) lo
wlp4s0 wifi unavailable --
Am I supposed to only have one at a time? I’ve never looked into/been aware of that.
Thanks for your advice
Do you think about something else Jorge?
Sorry that’s the only thing I got. ![]()
