Dotfiles and Custom Images
What would be the best way to integrate dotfiles and custom images?
I’m trying to create a sway image with dotfiles, but the solution I found to deal with this may not be better, I’m dealing with the dotfiles directly in the image instead of having a script that clones a git repository and copies the files to the user’s home on the first boot, what would be the best solution in this case? I thought about using chezmoi together with yafti, but I don’t know if that will work
How would you feel about adding a custom justfile command (or, for a more automated experience, a systemd user service running a custom script) which ensures that you have the latest version of your dotfiles, e.g. applied with chezmoi?
I just put mine in /usr/etc/skel. It’s not always updated though - skel is only copied at user creation, so I still need to periodically copy my files to my repo.
The other thing that I’ve been doing is putting my files in my home-manager repo, and using tmpfiles to symlink them so that the files in the local repo is always updated and I just need to commit and push them to GH repo.
If someone wanted to do a completely automated chezmoi setup I would ship that by default in Bluefin! It’d be nice to just have this ootb.
That would be cool and would help a lot
Opened an issue about this in blue-build/modules:
Please check out this pull request for this feature.
How do you deal with the dotfiles directly in the image ? i am having difficutly doing that, it seems it doesn’t want to go to .config, can you share something please.
Would this still be interesting? Bluebuild’s implementation seems pretty nice, I could port it over to Bluefin quite easily following their steps. I personally dont know if it would be super cool to mess around with people’s $HOMEs tho…
If you are using BlueBuild just use their module, otherwise it is kind of a complicated implementation to figure out if you havent done something like that already
Yes I am using bluebuild, can you be more specific please because I tried to set it up in their recipe file if it is what you mean and also I tried with a script but I don’t get the result I want which is simply to copy my dotfiles into the .config folder but I can copy them elsewhere for some reason which may not be very useful.
Stuff you put into /etc/skel gets copied to a new user’s $HOME automatically. Put your dotfiles in there
Thanx for your answer, I will try that.
I did as you said, put the dotfiles in the etc/skel/.config folder and added the source and destination in the modules of the recipe then created a new user on my laptop and after rebooting all the dotfiles got copied at the right place.
Thank you very much !
