DNS over TLS in Aurora
I just installed Aurora on an old ThinkPad T430s I have and am trying to get DNS over TLS to work.
I have tested that Control D works with
sudo resolvectl dns wlp2s0 76.76.2.22
sudo resolvectl dnsovertls wlp2s0 yes
sudo resolvectl dnssec wlp2s0 yes
but as soon as I reboot the configuration is lost.
You can set it up the same as you would on any distro. Maybe the easiest way is to set dns-over-tls (Network Manager config).
Enable DNS over TLS
Set dns-over-tls, by creating a config file:
cat << EOF | sudo tee /etc/NetworkManager/conf.d/90-dns-over-tls.conf >/dev/null
[connection]
connection.dns-over-tls=2
# 2 yes, 1 opportunistic, 0 no
EOF
Set Custom DNS Servers
Under System Settings > Networking > Wifi & Internet
  1. Switch your connection’s ipv4/ipv6 IP tabs’ methods to “Automatic (Only addresses)”
  2. Add the DNS servers you want to use (e.g. quad9)
Finally, restart Network Manager:
sudo systemctl restart NetworkManager
# check if settings applied:
systemctl status systemd-resolved
resolvectl status | grep -B2 -A3 '\+DNSOverTLS'
In case anyone wants to dive deeper, there have been some articles in Fedora magazine about it (ymmv):
