Dimming Software for Bazzite Handheld PC
Hey all,
I have an Ayaneo Air 1S running Bazzite and it’s overall a great experience, but the Ayaneo’s screen (although very high quality) is wayyyy too bright in most dark settings I use it in. I need to create some sort of software for Bazzite that will act like a black, transparent image over my entire screen in both Game Mode and Desktop Mode. This would act much like the Dimmer software on Windows.
Any help would be greatly appreciated! Hopefully if it’s customisable, I would love to be able to tie the opacity of the dimmer to my system’s brightness setting, where 0% brightness has the dimmer at 50% opacity and 100% brightness has 0% opacity.
I do currently use a dimming sticker over the whole screen but it makes putting on a screen protector not as viable, so I really do need a software fix for this.
i installed dimmer
Don’t be like the smug baboon over there. anyway.
I found an app on the bazaar that should do the trick its called “Luminance” Install Luminance on Linux | Flathub
