Desktop behaviour has changed - help
Hi, I’ve just booted up Bazzite this morning and my desktop has changed.
Firstly at the top left of the screen, there were two icons. One of which reduced size of desktop and made app bar visible. The second icon had a menu of actions and has now gone.
And talking of toolbar, it is invisible in normal use but pulling the mouse below the screen reduced desktop size and showed the app bar (like the button in top left corner) but now app bar does not appear and desktop does not reduce in size
I guess you are running the Gnome version of bazzite?
Check your gnome extensions if they have somehow disabled itself.
Thanks, went to extention manager and they were disabled at the global level. Turned back on and all is fixed. Thanks very much for your help.
