Cosmic Desktop variant planned?
Since Fedora already has an atomic Cosmic spin, is it planned to make a Bazzite version with Cosmic DE?
Sorry if this has been asked before. The only thing I found was an Aurora maintainer saying it will not be done for Aurora and I believe I saw someone say that it will be done for Bazzite only.
Is there an ETA on that by chance?
I tried to get Bazzite KDE to work for me, but it was too glitchy (as KDE has been the two other times I tried it, admittedly Plasma 6 is MUCH better). I suppose I can get over the cluttered feel, but not poor performance. For example when downloading on Steam, the whole system freezes up. I tried with and without hardware acceleration. It seems to be a KDE compositor or shell issue. I never experienced this with Gnome or Hyprland before.
I’d like to use Bazzite because I like the benefits of Atomic distros (and SElinux+secureboot with Fedora) and Bazzite has most of the stuff I need part of the image which won’t need to be layered, especially Steam and many others which is nice. Gnome is well, Gnome, and I don’t want to use it anymore.
Thanks!
I think you’re out of luck on that. Probably they don’t have the resources to maintain three different variants.
There are currently no plans to create a specific image for Cosmic.
There are some “3rd party” images based on ublue. One of the, which seems to be pretty well maintained is Origami Linux https://origami.wf/
Remember that “spins” are not official fedora supported. They are community supported using Fedora infrastructure.
There are only TWO officially supported desktop environments. Gnome and KDE.
Thanks! Appreciate all the info. Totally understandable as I’m sure it’s a lot of work to maintain another DE. I think I heard it was automated so I wasn’t sure. But I tried Cosmic Atomic with Steam Flatpak and it has it’s own issues. So I wouldn’t recommend Cosmic just yet anyway.
I will try Aurora with Steam Flatpak and see how that goes, otherwise I’ll just stay where I’m at for now.
You sound like you might have a hardware problem, maybe bad RAM. I had similar freezes and crashes a few years ago, and replacing one of my RAM sticks fixed them.
Thanks for the suggestion, valid point, but the only time I saw this was when on Bazzite. Aurora with Steam Flatpak is actually working great. I am thinking that my system does not like the kernel mods done to Bazzite.
And no issues with KDE either. In fact it’s fantastic after a bunch of customization to make it more keybind and multiple desktop focused. Have it very similar and clean like I had on Hyprland (sans tiling of course). Didn’t know you could remove title bars globally in the theme which is awesome and removes a lot of clutter.
Super impressed so far. Looking forward to just living my life and using my PC not having to worry about anything. Even though I can do a lot manually, I don’t get paid for it and work enough hours at my job already :slight_smile:
The same thing happened to me, my system worked fine with some distros and/or DEs, but I had problems with others, coincidentally those that took full advantage of the PC resources like RAM or disks.
