Since 42.20250427 update and still on 42.20250430 coolercontrol GUI is scrambled so it can not be used. Works fine on 42.20250417 update.
Still the same in latest update to 42.20250430 (2025-05-01T19:32:10Z)
Am I the only one with this problem?
Yeah, CoolerControl seems to be having graphic issues for some folks lately, myself included.
After finding this Issue over on the CoolerControl GitLab, I was able to have my CoolerControl display properly by right-clicking on CoolerControl in the Application Launcher; selecting “Edit Application…”; and then adding the following into the “Environment variables” field:
Exec=env QTWEBENGINE_FORCE_USE_GBM=0
Hopefully this will sort things for you as well.
Thank you Alehkhs!! Worked like a charm!
