I can’t get distrobox rm to delete a container:
❯ distrobox ls
ID | NAME | STATUS | IMAGE
992a366e5e06 | tst | Exited (1) 5 minutes ago | docker.io/library/clearlinux:latest
❯ distrobox rm -f tst
Removing exported binaries...
❯ distrobox ls
992a366e5e06 | tst | Exited (1) 2 seconds ago | docker.io/library/clearlinux:latest
I am not sure what the problem is. I can create other containers and remove them:
❯ distrobox create --name other --image debian:latest
Resolved "debian" as an alias (/etc/containers/registries.conf.d/000-shortnames.conf)
Trying to pull docker.io/library/debian:latest...
Getting image source signatures
Copying blob 609c73876867 done |
Copying config e15dbfac2d done |
Writing manifest to image destination
e15dbfac2d2b38406db17278673b8d905785386f916a843887115566d7a9d97a
Creating 'other' using image debian:latest [ OK ]
Distrobox 'other' successfully created.
To enter, run:
distrobox enter other
~ took 4s
❯ distrobox ls
992a366e5e06 | tst | Exited (1) About a minute ago | docker.io/library/clearlinux:latest
5d24f0977054 | other | Created | docker.io/library/debian:latest
❯ distrobox rm -f other
Removing container...
other
~ took 52s
❯ distrobox ls
992a366e5e06 | tst | Exited (1) 40 seconds ago | docker.io/library/clearlinux:latest
But this particular one (whose creation I interrupted with Ctrl-C) seems to have gone into some weird state. It simply won’t go away…
I also can’t enter the container:
❯ distrobox enter tst
Starting container... [ OK ]
Installing basic packages... [ OK ]
Setting up devpts mounts... [ OK ]
Setting up read-only mounts... [ OK ]
Setting up read-write mounts... [ OK ]
Setting up host's sockets integration... [ OK ]
Integrating host's themes, icons, fonts... [ OK ]
Setting up package manager exceptions... [ OK ]
Setting up distrobox profile... [ OK ]
Setting up sudo... [ OK ]
Setting up user groups... [ OK ]
Setting up kerberos integration... [ OK ]
Setting up user's group list... [ OK ]
Setting up existing user... [ OK ]
Setting up existing user: /etc/passwd... [ OK ]
Setting up existing user: /etc/group... Error: An error occurred
Any idea how to nuke this?
