Hi all,
I am testing Aurora in a VM with the aim of moving over to it on my laptop. I am having problems with Bottles. I have installed the flatpak - but I cannot add a program in my KDE Applications menu.
To do this I need to run the command - flatpak override com.usebottles.bottles --user --filesystem=xdg-data/applications
But if I reboot after running the command, it still does not work. Does anyone have any ideas?
Thanks if you can help ![]()
