Bootc critical errors
Just ran my daily check using bootc (sudo bootc upgrade) and I got the following error:
❯ sudo bootc update
layers already present: 67; layers needed: 5 (501.8 MB)
Fetched layers: 478.58 MiB in 31 seconds (15.25 MiB/s)                                       ⠓ Deploying
(bootc:30269): GLib-CRITICAL **: 08:37:03.637: g_atomic_ref_count_dec: assertion 'old_value > 0' failed
(bootc:30269): GLib-CRITICAL **: 08:37:03.645: g_atomic_ref_count_dec: assertion 'old_value > 0' failed
(bootc:30269): GLib-CRITICAL **: 08:37:03.674: g_atomic_ref_count_dec: assertion 'old_value > 0' failed
⠉ Deploying
(bootc:30269): GLib-CRITICAL **: 08:37:03.895: g_atomic_ref_count_dec: assertion 'old_value > 0' failed
(bootc:30269): GLib-CRITICAL **: 08:37:03.896: g_atomic_ref_count_dec: assertion 'old_value > 0' failed
(bootc:30269): GLib-CRITICAL **: 08:37:03.911: g_atomic_ref_count_dec: assertion 'old_value > 0' failed
(bootc:30269): GLib-CRITICAL **: 08:37:03.913: g_atomic_ref_count_dec: assertion 'old_value > 0' failed
(bootc:30269): GLib-CRITICAL **: 08:37:03.915: g_atomic_ref_count_dec: assertion 'old_value > 0' failed
(bootc:30269): GLib-CRITICAL **: 08:37:03.923: g_atomic_ref_count_dec: assertion 'old_value > 0' failed
(bootc:30269): GLib-CRITICAL **: 08:37:03.925: g_atomic_ref_count_dec: assertion 'old_value > 0' failed
  Deploying: done (13 seconds)                                                               Pruned images: 0 (layers: 0, objsize: 386.6 MB)
Queued for next boot: ostree-image-signed:docker://ghcr.io/ublue-os/bluefin:latest
  Version: latest-42.20250423.1
  Digest: sha256:55028952fe1f66ef4294c81ef8bc4b6efb7c02eefb8ede1a604b6f2adb5b78cb
Total new layers: 72    Size: 3.4 GB
Removed layers:   5     Size: 502.1 MB
Added layers:     5     Size: 501.8 MB
Is it stuck there or does a prompt come back?
The prompt does come back.
Happened again this morning.
Does the update apply? Like if you reboot does it go into the right image?
Yes. It appears to have applied. It just drops those disconcerting errors during the process. I suspect it’s the bit of code that lists the changes.
I’m getting these too when I sudo bootc update with my custom image. I usually use rpm-ostree update to update my system, the first time I started using bootc update was while testing my custom image. Not sure if these are expected outputs, and they don’t seem to have any affect on my system.
