Bluefin - Using distrobox with vscode tasks
I have performed 4 experiments thus far, and this one supplied unexpected glee.
Sometimes you just need to get things done. So reach into your toolbox and voila!
- Bluefin - use podman distrobox container in vscode
- Bluefin - use docker distrobox container in vscode
- Bluefin - rely on OCI layer sharing for distrobox and devcontainer
- Bluefin - Using distrobox with vscode tasks
Problem Statement
As a developer using one of the bluefin-dx bootc images, I would like:
- Given a VS Code project that needs multiple processes to start testing
- One of the processes can run on the host given what I have installed with
brewor installed into my$HOMEdir - But one of the processes needs to run in a
distroboxrunning on my host
I really should define a devcontainer, but …
Approach
Given the context described above I opted to construct a compound vscode task.
One of the tasks just executes with what I have on the host.
The other task uses distrobox enter box-name -- command to execute on my running distrobox.
But the first task ties them both together for the DX for which I was looking.
Expand to see sample .vscode/tasks.json
"version": "2.0.0",
"tasks": [
"label": "Full Stack",
"dependsOn": [
"Tailwind Dev Server",
"Django Dev Server",
"label": "Tailwind Dev Server",
"type": "shell",
"command": "distrobox",
"args": [
"enter",
"fedora41-python-dx",
"pnpm",
"run",
"dev"
"options": {
"cwd": "${workspaceFolder}"
"label": "Django Dev Server",
"type": "shell",
"command": "pdm",
"args": [
"manage",
"runserver"
"options": {
"problemMatcher": [
"$python"
Use the Command Palette command Tasks: Run Task and select Full Stack (first item in the .vscode/tasks.json file) from the drop down to launch all processes to start developing.
This will run pnpm run dev in the fedora41-python-dx distrobox, and pdm manage runserver on the host. They will start in separate vscode terminal processes.
Enjoy!
