Bluefin-cli.container pull timeout 5m0s exceeded
How do I increase or eliminate the pull timeout when trying to run bluefin-cli for the first time? I have very slow internet (~3Mbps) and it always times out after 5 minutes:
❯ systemctl --user status bluefin-cli.service
× bluefin-cli.service - Bluefin CLI, leveraging Wolfi to provide you brew
     Loaded: loaded (/etc/containers/systemd/users/bluefin-cli.container; generated)
    Drop-In: /usr/lib/systemd/user/service.d
             └─10-timeout-abort.conf
     Active: failed (Result: timeout) since Sun 2024-08-11 13:55:12 EDT; 2min 34s ago
    Process: 1085884 ExecStartPre=/usr/libexec/ptyxis-remove-profile.sh bluefin-cli (code=exited, status=0/SUCCESS)
    Process: 1085896 ExecStart=/usr/bin/podman run --name=bluefin-cli --cidfile=/run/user/1000/bluefin-cli.cid --replace --rm --cgroups=split --network=host --sdnotify=conmon -d --ulimit host --user root:root ->
    Process: 1088288 ExecStopPost=/usr/bin/podman rm -v -f -i --cidfile=/run/user/1000/bluefin-cli.cid (code=exited, status=0/SUCCESS)
   Main PID: 1085896 (code=exited, status=0/SUCCESS)
        CPU: 8.173s
Aug 11 13:50:57 jelly bluefin-cli[1085896]: Pulling image //ghcr.io/ublue-os/bluefin-cli:latest inside systemd: setting pull timeout to 5m0s
Aug 11 13:50:58 jelly bluefin-cli[1085896]: Getting image source signatures
Aug 11 13:50:58 jelly bluefin-cli[1085896]: Checking if image destination supports signatures
Aug 11 13:50:58 jelly bluefin-cli[1085896]: Copying blob sha256:36bf7dfa75db60df0c466b1c0b9b7dd5b52b78361c8a6f98a678af1518fb82c8
Aug 11 13:50:58 jelly bluefin-cli[1085896]: Copying blob sha256:79124ef23a07d3ca9b43a7d6f157387e5cdc7f99ca0ffa77cb77277af9ba169b
Aug 11 13:50:58 jelly bluefin-cli[1085896]: Copying blob sha256:b228d01a5ca322fb4379cfde90c8e0368c4c491088f1e5105e70a07c2685e14a
Aug 11 13:55:12 jelly systemd[6154]: bluefin-cli.service: start operation timed out. Terminating.
Aug 11 13:55:12 jelly systemd[6154]: bluefin-cli.service: Failed with result 'timeout'.
Aug 11 13:55:12 jelly systemd[6154]: Failed to start bluefin-cli.service - Bluefin CLI, leveraging Wolfi to provide you brew.
Aug 11 13:55:12 jelly systemd[6154]: bluefin-cli.service: Consumed 8.173s CPU time, 85.1M memory peak, 0B memory swap peak.
Maybe just pull the container by hand and wait for it to finish then restart the service?
Thank you, Jorge. Sorry for the delayed reply.
Yes, it was sufficient to just run podman pull ghcr.io/ublue-os/bluefin-cli:latest, and once it completed then Meta+Enter entered the container.
