I am trying to install battle.net via Lutris and am hitting trouble with the bnet login window. It doesn’t seem to render the window properly showing mostly blank (see below). If I move my mouse back and forth over the window I can sometimes see elements (email field, login button etc) very briefly before disappearing again.
Hi I used Faugus, you install it, click add (bottom left) , then where it says “Windows game” click the text and there is an option for battle net, it will install it automatically (and for me at least ) it ran fine, played WoW excellently
I was having issues the other day with proton 10.0 and GE 10.26 (I think). I switched to proton experimental and that fixed it for me through Lutris. Presuming it was working previously and now its acting up, I would try some different proton versions
Is this the first install? are you not suppose to close the login first time it pops up. Did you do that? For me I use Heroic to lunch battle.net and all other game launchers since it works better in my experience.
