I have shuttle with an amd firepro 710 graphics card and four displays cabled with display port. The displays periodically flicker, which can be annoying. dmesg has only one amdgpu error:
sudo dmesg --level=err,crit|grep amdgpu
[ 5.501805] [drm:amdgpu_get_bios [amdgpu]] *ERROR* failed to evaluate ATRM got AE_AML_BUFFER_LIMIT
which I don’t yet understand. Any recommendations on next steps?
Here’s the configuration via inxi. Yeah, it’s a dump, but I’m not really sure what I’m looking for, so I enumerated the machine, the graphics drivers and the displays.
sudo $(type -p inxi) --edid --cpu --machine --system
System:
Host: atlantic Kernel: 6.9.4-100.fc39.x86_64 arch: x86_64 bits: 64
compiler: gcc v: 2.40-14.fc39 clocksource: tsc avail: acpi_pm
parameters: BOOT_IMAGE=(hd3,gpt2)/ostree/default-780155f41d1f19c6a24939a09a005d00915e0f8c54e27d3532f63710f3af3baf/vmlinuz-6.9.4-100.fc39.x86_64
rhgb quiet root=UUID=192584dc-396e-4c6d-9e4a-cd1d0bd6ce33
rootflags=subvol=root rw
ostree=/ostree/boot.1/default/780155f41d1f19c6a24939a09a005d00915e0f8c54e27d3532f63710f3af3baf/0
rd.luks.options=discard
Console: pty pts/7 wm: gnome-shell DM: GDM v: 45.0.1 Distro: Fedora Linux
39.20240618.0 (Silverblue)
Machine:
Type: Desktop Mobo: Shuttle model: SH570 v: 1.0 serial: N/A
uuid: 1273ee80-f497-5b6e-0000-000000000000 UEFI: American Megatrends LLC.
v: 1.03 date: 05/25/2021
CPU:
Info: model: Intel Core i9-10900 socket: U3E1 bits: 64 type: MT MCP
arch: Comet Lake gen: core 10 level: v3 note: check built: 2020
process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 5
microcode: 0xF8
Topology: cpus: 1x cores: 10 tpc: 2 threads: 20 smt: enabled cache:
L1: 640 KiB desc: d-10x32 KiB; i-10x32 KiB L2: 2.5 MiB desc: 10x256 KiB
L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 1260 high: 4661 min/max: 800/5200 base/boost: 2772/5200
scaling: driver: intel_pstate governor: powersave volts: 0.8 V
ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 800 5: 4661 6: 800
7: 2088 8: 1628 9: 801 10: 800 11: 800 12: 3766 13: 1064 14: 800 15: 800
16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 111997
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Vulnerabilities:
Type: gather_data_sampling mitigation: Microcode
Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
Type: reg_file_data_sampling status: Not affected
Type: retbleed mitigation: Enhanced IBRS
Type: spec_rstack_overflow status: Not affected
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via
prctl
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer
sanitization
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB:
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
loop
Type: srbds mitigation: Microcode
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: Holco Enterprise
Co /Shuttle driver: i915 v: kernel arch: Gen-9.5 process: Intel 14nm
built: 2016-20 ports: active: HDMI-A-2 empty: DP-1, DP-2, HDMI-A-1,
HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:9bc5 class-ID: 0300
Device-2: AMD Tonga PRO GL [FirePro W7100] driver: amdgpu v: kernel
arch: GCN-3 code: Volcanic Islands process: TSMC 28nm built: 2014-19 pcie:
gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-3, DP-4, DP-5, DP-6
empty: none bus-ID: 01:00.0 chip-ID: 1002:692b class-ID: 0300 temp: 71.0 C
Device-3: Sunplus Innovation Depstech webcam MIC
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-12.2.1.3:69 chip-ID: 1bcf:28c4 class-ID: 0102
serial: 01.00.00
Display: server: X.org v: 1.20.14 with: Xwayland v: 23.2.7
compositor: gnome-shell driver: X: loaded: fbdev,modesetting,vesa dri: iris
gpu: amdgpu,i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 7680x4032 s-size: <missing: xdpyinfo>
Monitor-1: DP-3 pos: 2-1 model: LG (GoldStar) Ultra HD serial: 57600
built: 2021 res: 2560x1440 hz: 60 dpi: 108 gamma: 1.2 chroma: red: x: 0.655
y: 0.333 green: x: 0.306 y: 0.639 blue: x: 0.149 y: 0.059 white: x: 0.314
y: 0.329 size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9
modes: 3840x2160, 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768,
800x600, 720x480, 640x480
Monitor-2: DP-4 pos: primary,2-2 model: LG (GoldStar) Ultra HD
serial: 26589 built: 2021 res: 2560x1440 hz: 60 dpi: 108 gamma: 1.2 chroma:
red: x: 0.655 y: 0.333 green: x: 0.306 y: 0.639 blue: x: 0.149 y: 0.059
white: x: 0.314 y: 0.329 size: 600x340mm (23.62x13.39")
diag: 690mm (27.2") ratio: 16:9 modes: 3840x2160, 2560x1440, 1920x1200,
1920x1080, 1600x1200, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
1152x864, 1280x720, 1024x768, 800x600, 720x480, 640x480
Monitor-3: DP-5 pos: 2-4 model: LG (GoldStar) HDR 4K serial: 639322
built: 2021 res: 2560x1440 hz: 60 dpi: 108 gamma: 1.2 chroma: red: x: 0.682
y: 0.314 green: x: 0.278 y: 0.675 blue: x: 0.153 y: 0.047 white: x: 0.314
Monitor-4: DP-6 pos: 1-2 model: LG (GoldStar) HDR 4K serial: 639323
Monitor-5: HDMI-A-2 mapped: HDMI-2 pos: 3-3 model: Artist 24 Pro
serial: 538969364 built: 2019 res: 2048x1152 hz: 60 dpi: 98 gamma: 1.2
chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149
y: 0.059 white: x: 0.314 y: 0.329 size: 530x300mm (20.87x11.81")
diag: 604mm (23.8") ratio: 16:9 modes: 2560x1440, 1920x1200, 1920x1080,
1920x1080i, 1600x1200, 1680x1050, 1280x1024, 1200x960, 1152x864,
1280x720, 1024x768, 800x600, 720x576, 720x576i, 720x480, 720x480i,
640x480, 720x400
EDID-Warnings: 1: parse_edid: unknown flag 16
API: OpenGL v: 4.6 vendor: intel mesa v: 23.3.6 glx-v: 1.4 es-v: 3.2
direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CML GT2)
device-ID: 8086:9bc5 memory: 122.23 GiB unified: yes
API: EGL Message: EGL data requires eglinfo. Check --recommends.
