It seems that if I have changed any network settings and I reboot my machine, a new network gets created with the original settings and it uses that instead. For example I keep trying to enable wake on lan. After I run the nmcli command to modify the connection to enable wake on lan, if I reboot a new connection is created that doesn’t have wol enabled and it is being used.
nmcli c show
NAME UUID TYPE DEVICE
Wired Connection 1b022931-67c0-45ed-b0a9-ce4aeb11d58f ethernet enp11s0
lo 93433db9-c934-4237-9e27-bf6e5d6fff36 loopback lo
Joseph's S23 Ultra Network 7ede4f9b-f350-42b3-877d-a58b261dbfe0 bluetooth --
Wired Connection 9bf51875-e648-4006-9253-b63c19ba4423 ethernet --
The other thing to note is that I had deleted that Joseph's S23 Ultra Network
before I rebooted. So, not only did it recreate Wired Connection
it also recreated Joseph's S23 Ultra Network
. Something else must be attempting to control the state of my network connections and I don’t know what it is.
