Fedora Silverblue Ublue.
I created files:
/etc/dconf/db/local.d/04-custom-folders
/etc/dconf/db/local.d/05-custom-ptyxis
/etc/dconf/profile/user
with this settings:
user-db:user
system-db:local
I did dconf update
, reboot the system and my custom settings are not applied.
After doing settings export: dconf dump / > dconf-settings.txt
it shows custom settings are saved. Dconf Editor app does not have any custom settings, that’s way they are not set and running.
Generally I do not get any errors running dconf commands and settings content is correct.
What else to do?
