Issue installing OCR integration in spectacle
Hello, I’m attempting to install this particular code from github GitHub - funinkina/spectacle-ocr-screenshot: A simple utility to automatically extract text from spectacle on plasma desktops.
It is meant to make it so that you can take a screenshot using spectacle and automatically perform OCR on it, outputting a small popup text window. I’m recently migrated from windows 10, and am attempting to copy a similar functionality I used very often.
I’m specifically stuck on actually getting it to run, getting the following error : ./spectacle-ocr-screenshot: error while loading shared libraries: libtesseract.so.5: cannot open shared object file: No such file or directory
I had many issues trying to get it to this part, including using distrobox to install tesseract and the other requirements, but I had a lot of help and am generally lost on how to search for what to try next.
I have posted an identical request on the bazzite discord, and user asen23 has provided a potential path to actually resolve this issue (just mentioned layering), but also a completely reasonable alternative that just works called Frog.
The specific issue is not resolved for me, but it is no longer my issue.
