# How to switch keyslots during boot decryption/unlocking when having a LUKS TPM2-keyslot with PIN?
**URL:** <https://universal-blue.discourse.group/t/how-to-switch-keyslots-during-boot-decryption-unlocking-when-having-a-luks-tpm2-keyslot-with-pin/12551>\
**Category:** Bazzite\
**Created:** [September 27, 2026, 12:05pm UTC](https://universal-blue.discourse.group/t/how-to-switch-keyslots-during-boot-decryption-unlocking-when-having-a-luks-tpm2-keyslot-with-pin/12551 "2026-09-27T12:05:28Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![rugk](https://yyz2.discourse-cdn.com/free1/user_avatar/universal-blue.discourse.group/rugk/32/6325_2.png) [@rugk](https://universal-blue.discourse.group/u/rugk)\
**Post date:** [September 27, 2026, 12:05pm UTC](https://universal-blue.discourse.group/t/how-to-switch-keyslots-during-boot-decryption-unlocking-when-having-a-luks-tpm2-keyslot-with-pin/12551/1 "2026-09-27T12:05:29Z")
</div>
### What I did
I used the `ujust setup-luks-tpm-unlock` command, which uses [the script `/usr/libexec/luks-enable-tpm2-autounlock`](https://github.com/blue-build/base-images/blob/e8b0a58dfc0d7275ef2fb2a61b96d3df158ff250/files/base/usr/libexec/luks-enable-tpm2-autounlock), which in the end also just uses `systemd-cryptenroll`.
However **I added a PIN** for the TPM2 for added security. So the command likely is like this:
```console
$ systemd-cryptenroll --tpm2-device=auto --tpm2-pcrs=7+14 --tpm2-with-pin=yes "$CRYPT_DISK"
I had a password for LUKS setup before, and **I want to keep it** , also as a recovery path or e.g. for having multiple people to have different unlock methods.
One can also see that both keyslots are still in there:
```console
# systemd-cryptenroll ****
SLOT TYPE
   0 password
   1 tpm2
# cryptsetup luksDump /dev/disk/by-uuid/ ****
LUKS header information
Version: 2
Epoch: 5
Metadata area: 16384 [bytes]
Keyslots area: 16744448 [bytes]
UUID: ******
Label: (no label)
Subsystem: (no subsystem)
Flags: (no flags)
Data segments:
  0: crypt
        offset: 16777216 [bytes]
        length: (whole device)
        cipher: aes-xts-plain64
        sector: 512 [bytes]
Keyslots:
  0: luks2
        Key: 512 bits
        Priority: normal
        Cipher: aes-xts-plain64
        Cipher key: 512 bits
        PBKDF: argon2id
        Time cost: 7
        Memory: 1048576
        Threads: 4
        Salt: ******
        AF stripes: 4000
        AF hash: sha256
        Area offset:32768 [bytes]
        Area length:258048 [bytes]
        Digest ID: 0
  1: luks2
        Key: 512 bits
        Priority: normal
        PBKDF: pbkdf2
        Hash: sha512
        Iterations: 1000
        Salt: ******
        AF stripes: 4000
        AF hash: sha512
        Area offset:290816 [bytes]
        Digest ID: 0
Tokens:
  0: systemd-tpm2
        tpm2-hash-pcrs: 7+14
        tpm2-pcr-bank: sha256
        tpm2-pubkey:
                    (null)
        tpm2-pubkey-pcrs:
        tpm2-primary-alg: ecc
        tpm2-pin: true
        tpm2-pcrlock: false
        tpm2-salt: true
        tpm2-srk: true
        tpm2-pcrlock-nv: false
        tpm2-policy-hash:
        tpm2-blob: ******
        Keyslot: 1
Digests:
  0: pbkdf2
        Hash: sha256
        Iterations: 122040
        Salt: ******
        Digest: ******
## Problem
Now, when booting, one can enter the PIN and TPM-unlock works flawlessly. The problem is: **There is no way to still use the passphrase** that I can see - despite it being still **available** as a keyslot.
When booting and I am at the unlock screen, I can press Esc to see all log details. And there you can see it similar to “Requesting PIN for TPM:”.
If one enters the wrong PIN there, the requests just keeps showing up.
Does not this make having a recovery passphrase a moot point? If I cannot switch to it to use it for unlocking in practice.
Say I e.g. forget my TPM PIN. I cannot unlock and boot the device anymore?
Note I know I _may_ be able to unlock it by booting some live system etc. and then maybe remove the tpm keyslot. But really, this is no useful point.
### What I would have expected
Maybe to just take the entered “PIN”, which is also just like a “password” (aka it does not have to be numeric at all), and also check it against the passphrase keyslots.
If anyone unlocks that is fine, the user provided the correct one.
**Alternatively** though IMHO not that sleep: Somehow allow the user to switch authentication methods, at least when entering one does not work.
## Another use case: multi-user
Also, to demonstrate a use case here why that may be useful beyond simple recovery is: multi-user setups. Linux is good for multi-users to use and at userland has good user segregation. However to decrypt an encrypted disk at startup, sharing a password would be bad. So either add a new password or TPM-unlock?
That said, people are reasonably weak at choosing passwords and in general, I thought, yeah using TPM2 surely can only increase security here, after all you can couple it with the PIN. The idea was: **Unlocking works with the usual password and TPM2 with PIN.**
Apparently, that does not work and just because of a “input/password request” problem. Technically, as far as I see, everything is set up for it. And that’s sad.
Or is there anything one can do here?
## Docs
I checked multiple LUKS and [systemd-cryptenroll docs](https://wiki.archlinux.org/title/Systemd-cryptenroll), but found this special case (TPM with PIN) nowhere to be explained in detail.
