Garbled Steam
Hi,
I’ve just started using Bazzite and today in Steam I see this:
Could it be that today’s update caused a problem or is it just a setting in Steam I have set? I’m wondering if anyone else has seen this.
Edit: I figured it out. In the Interface Settings in Steam we can not use a choice other than Automatic. At least I can’t. I have a very standard system so I won’t be the only one effected.
I can’t get games to launch on Steam, though. I rolled back to 30th June (which I started on and pinned just in case), and it still doesn’t launch any games. So I dunno what’s up with that.
Edit2: Ok. Well I’ll go try out EndeavourOS instead, then.
