I had previously been using an NVidia RTX 3060 TI GPU in my system and was running an image based on ghcr.io/ublue-os/bazzite-gnome-nvidia
I recently purchased an AMD Radeon RX 9070 XT and swapped it into my system.
Before going too deep into customizing my image, I chose to rebase to the vanilla ghcr.io/ublue-os/bazzite-gnome image using brh rebase bazzite-gnome:stable
When I rebooted the system, the rebase had not happened and I saw a semi-familiar message in the output of rpm-ostree status that I needed to check journalctl -b -1 -u ostree-finalize-staged.service
$ journalctl -b -1 -u ostree-finalize-staged.service
Jun 06 04:09:21 infidelicious systemd[1]: Finished ostree-finalize-staged.service - OSTree Finalize Staged Deployment.
Jun 06 15:44:46 infidelicious systemd[1]: Stopping ostree-finalize-staged.service - OSTree Finalize Staged Deployment...
Jun 06 15:44:47 infidelicious ostree[251851]: Finalizing staged deployment
Jun 06 15:44:48 infidelicious ostree[251851]: Copying /etc changes: 58 modified, 0 removed, 238 added
Jun 06 15:44:48 infidelicious ostree[251851]: Refreshing SELinux policy
Jun 06 15:44:48 infidelicious ostree[251922]: libsemanage.semanage_direct_get_module_info: Unable to open nvidia-container module lang ext file at /etc/selinux/targeted/tmp/modules/400/nvidia-container/lang_ext. (No such file or directory).
Jun 06 15:44:48 infidelicious ostree[251922]: semodule: Failed!
Jun 06 15:44:48 infidelicious ostree[251851]: Refreshed SELinux policy in 389 ms
Jun 06 15:44:48 infidelicious ostree[251851]: error: Finalizing deployment: Finalizing SELinux policy: Child process exited with code 1
Jun 06 15:44:48 infidelicious systemd[1]: ostree-finalize-staged.service: Control process exited, code=exited, status=1/FAILURE
Jun 06 15:44:48 infidelicious systemd[1]: ostree-finalize-staged.service: Failed with result 'exit-code'.
Jun 06 15:44:48 infidelicious systemd[1]: Stopped ostree-finalize-staged.service - OSTree Finalize Staged Deployment.
Jun 06 15:44:48 infidelicious systemd[1]: ostree-finalize-staged.service: Consumed 910ms CPU time over 11h 35min 27.121s wall clock time, 125.3M memory peak.
I threw the problem a Claude Code and it thankfully was able to help resolve the issue. I’ll just post it’s reasoning here:
● The rebase succeeded. Here’s what happened and what I did:
Root cause: The
nvidia-containerSELinux module (a legacy binary.ppformat, owned byublue-os-nvidia-addons) was causingsemoduleto fail during ostree’s deployment finalization. Specifically,libsemanagewas unable to write thelang_extfile into its temporary working directory while rebuilding the SELinux policy store for the new deployment. Thesemodule --refreshcall on the running system worked fine, but it failed when ostree ran it in the context of the staged deployment.What I did: Removed the
nvidia-containerSELinux module withsudo semodule -r nvidia-container, which cleared the problematic state from the local/etc/selinuxstore. Then re-ran the rebase.The rebase to
bazzite-gnome:stablestaged successfully. Key things in the diff to be aware of:
- The new image removes
ublue-os-nvidia-addons(and with it the problematicnvidia-container.ppmodule) — this is why it caused the conflict during finalization.- All the NVIDIA driver packages (
nvidia-driver,nvidia-container-toolkit, etc.) are removed in the new image — so this is a switch away from your custom nvidia-enabled image to the standard bazzite-gnome.- A new
ublue-os-selinux-workaroundspackage is being added, suggesting upstream bazzite has addressed SELinux issues like this one.You can now reboot to apply the changes:
systemctl reboot
With the offending SELinux module removed, the rebase succeeded and I successfully rebooted into the new image.
I don’t know if this is “technically correct”, but it got me up and running.
