Desktop mode : Color issue
Hello Community !
Sometimes when i boot into desktop mode (Bazzite-Deck image) , colors are washed out and i need to reboot for this problem to be solved.
Does anyone experience the same thing ?
Any solutions ?
Many thanks
Well, I can only tell you what I have.
All adaptive settings are turned off, night lighting is off.
Color resolution is at 10 bit, and accuracy is set for, well, accuracy. And EDR is on.
But it could also be some overlay from a program that is failing to start.
Thank you for sharing your settings.
I will try to change settings here and there and see how it goes.
Also, make sure it’s nothing as simple as ECO mode on the monitor.
