Can't create transaction lock
Hi,
I’m trying to install cabextract, so I can install ms fonts on Aurora. I’ve run the install command as a normal user and as root and received the same error (error: can’t create transaction lock on /usr/share/rpm/.rpm.lock (Read-only file system)) on both occasions. I searched for processes that might be causing the lock without luck. Any suggestions?
/usr is not writable, so you are propably trying to run some kind of scripts to install those. That won’t work
these might work MS Core Fonts on Silverblue - #8 by axels - Fedora Discussion
You should use brew: brew install cabextract
Many Thanks, will give it a go.
Many thanks will give it a go
