Bazzite doubts in Framework 16
Hi, I’m thinking about installing Bazzite on my framework 16 ,but I have a few questions:
-Does it have integration with GOG, Epic, and Xbox Store games?
-Will I be able to get achievements, stats, or cloud saves on GOG and Epic?
-Does it have integration to limit the FPS, change the TDP, or control the PC’s fans?
-Does it have a mode with the SteamDeck menu so I can just use my gamepad without needing a keyboard and mouse?
Yes to everything except the Xbox Store games. You can only stream those with xbox cloud.
