I have been running Bazzite flawlessly for over 12 months now with the only issue arising is comparability on some steam games.
A few days ago I began to see a boot/loading issue. Previously if I delayed logging in for a couple of minutes the hdmi video signal would appear to put the screen into sleep mode.
Moving the mouse about or tapping the keyboard would generally fix this.
Now nothing recovers the monitor.
Currently when starting bazzite, bios loads up followed by Grub loading then a flashing cursor for about 20 blinks then the screen signal drops off.
I downloaded the lasted bazzite iso to a scandisk usb drive to attempt to rectify the problem.
after loading bazzite. selecting the repair option. repair boot option. I get the boot partition
cannot be found error even after trying all the obvious partition options. The only way I can get Bazzite to run is to boot from bios and select the “san” option not the efi option from the
usb bazzite boot drive.
I have left the pc running to try to get an answer on how to fix this.
I hope someone has come across this issue and knows how to fix this.
Cheers Gelignite
This is just a wild shot to see if it’s of any use to you:
It really doesn’t sound like what you’re talking about. But, it’s the only thing I’ve seen that comes close. EDIT: Also, it’s an old video, so things might be different.
Also, it’s odd that your system will go to Sleep if you don’t sign in immediately after booting. I just opened an Issue because my system doesn’t use any of the Power Management settings (i.e., Sleep) until after first logon:
